450 sleeve in M block
tcoop
11-14-2006 09:35:51
will a 450 sleeve go into a M block without modification?
tcoop
11-14-2006 12:46:16
 Re: 450 sleeve in M block in reply to tcoop, 11-14-2006 09:35:51
What about a 450 sleeve in a super m block?
cousin_gary
11-14-2006 12:53:26
 Re: 450 sleeve in M block in reply to tcoop, 11-14-2006 12:46:16
Yes a 450 sleeve will go in to a Super M block. The Super m, 400 aned 450 all have the same block. The only diff is on the 450, which has a larger displacement on it. c281 vs c264
ChadS
11-14-2006 12:52:23
Drops right in! I have a 450 sleeve/piston kit in a M block in my puller, had to bore it to 4.25, and have the 450 sleeve flange cut down to the M flange specs, dropped em right in no problems. real good low gear puller! lots of low end torque. Chad
MJF
11-14-2006 10:59:01
You must bore the block
RichH
11-14-2006 19:12:48
 Re: 450 sleeve in M block in reply to MJF, 11-14-2006 10:59:01
Some of the M blocks don't survive a 4.25 bore without striking water. IT happened to me.
