DC Case Cam specs
MO puller
11-15-2006 12:08:54
Hello do any of you guys know the stock cam specs for a DC case? Or if you have had one redone by someone who done it and what kind of a grind did they put on it? thanks
dboll
11-16-2006 05:06:39
 Re: DC Case Cam specs in reply to MO puller, 11-15-2006 12:08:54
Berry did the cam for my 331 inch CC and it makes good power from idle to 1800rpm, I will check the cam grind #
DCPULLER
11-15-2006 14:39:59
Here's the specs of my Berry ground cam:
cam grind 95-B
cam lift 285 intake and exhaust
duration at .050 204 intake and exhaust
seat duration at lifter lift 260 intake and exhaust
110 degree lobe seperation
Cam makes good power with 4 1/16 domed m@ws with shaved 5505 head and a reworked Motec carb. Dave S
