Custom wide front end.
TimC
04-17-2002 18:22:50
Can anyone give me a good lead on parts to build a custom front end. Tubing and tierods are not the issue. Need the post/knuckle or what ever it is reffered to. I can get 2000 lb spindles and hubs locally. It needs to be clean, light, and easily welded to. 6 to 8 inches tall so the front axle stays below the top of the tire, I can find or build the steering arms. Don't want to have to cut and shorten something off an OEM part but that is the option so far. Does the local CO-OP or Tractor Supply have these parts. Hay wagon builders aren't to plentiful around here.
cd
04-17-2002 19:35:48
 Re: Custom wide front end. in reply to TimC, 04-17-2002 18:22:50
I assume you are talking about the center pivot point, I don't see why you couldn't fab it up using 1 inch plat, maybe thicker and some D.O.M. tubing for the main pin to slide through.
TimC
04-18-2002 06:46:54
 Re: Re: Custom wide front end. in reply to cd, 04-17-2002 19:35:48
No, the part that might normally be called the king pin, but I don't want the type that has a collar on top and bottom with the king pin between and the spindle attached to it. What I need is a sleve with a steering arm above it and heavy steel pin going down thru it that would then connect to the spindle. The square tubing for the axle will then be welded to the sleve.
