1st Reduction gear, JD A and B
MDM
11-23-2006 08:39:27
Is it possible to change the 1st reduction gear to slow down a styled 2 stick 6 speed A or B? If so, what do i need
Rusty Junk TX
11-25-2006 19:00:05
 Re: 1st Reduction gear, JD A and B in reply to MDM, 11-23-2006 08:39:27
On an A, YES all the way back thru unstyled and it fits inside all the first reduction covers. On a B, NO. I here it has to do with the splines.
Marcus
JohnDeere_John
11-24-2006 05:33:00
Another question? Is it possible to put the faster gears in 51 OR 52 A OR 60 TO SPEED THEM UP?
Jon
jim jones
11-23-2006 14:56:04
yes it is possible----you need to get a reduction gear set from a newer JD A one with staight six speed. should slow ya down about an 1/8 mile per hr.
jd lover
11-23-2006 16:07:38
 Re: 1st Reduction gear, JD A and B in reply to jim jones, 11-23-2006 14:56:04
Why slow down?Every pull i have ever been at the creeper gear tractors get creamed.I pull a '48 "A" and consistentaly beat the six speed creepers.Personally bore it a little and shave the head.My 2 cents worth,good luck.
