ChadS
11-28-2006 09:12:22
Re: Farmall H Piston Size in reply to toot, 11-28-2006 08:40:12
Yes, there is a Massey 44 Flat top piston that has a 4 inch bore, 2.5 compression height, (same as H IH) Has a 1.25 wrist pin diameter. Now, its possible to put the big Massey pin in the H rod, Id have to measure how thick the H wrist pin bushing is, and see how it can be done. I know it can be done, its been a while since Ive thought of that setup,,, On the Block,,, if the 350 block will go out to 4 inch bore,,, They have been known to go out that far without putting in sleeves, but, Id have sleeves put in and hard block the water jackets. you have a better chance of having a thicker cyl wall that way. Ive got a big bore 350 block with wet sleeves put in,,, set up to go to 4 inch,,, and have a very thick sleeve,,, Id let go pretty reasonable. Id betcha that with the 4 inch bore and get the compresion up by using a good cyl head,,, 55-60+hp and thats real good without a stroker crank. ChadS
