Farmall ring pinion info
superih
11-29-2006 05:21:31
FYI
Farmall M ring & pinion teeth 19 and 50 for a 2.63/1 ratio.
W6 ring & pinion teeth 19 and 47 for a 2.47/1 ratio.
The W6 will give you a 6.4% speed increase in each gear.
Charles McNelly III
12-01-2006 19:29:57
 Re: Farmall ring pinion info in reply to superih, 11-29-2006 05:21:31
Guy Fays Farmall Book claims the rear was the same on the W-6 and the M. I wonder what the difference in tire height was between the two tractors? Charles
B BARENIE
11-29-2006 17:52:15
IS THIS INFORMATION EXACT. !
superih
11-30-2006 05:46:10
 Re: Farmall ring pinion info in reply to B BARENIE, 11-29-2006 17:52:15
Yes - I counted the teeth on the gears myself. I cannot find rolling circumference for 15.5x38 or 13.6x38. Anyone know of a chart showing this?
This is pretty interesting. I created a spreadsheet that calculates MPH in each gear for a given tire size, engine rpm, ring&pinion, etc. With 16.9 x 38 tires a Super M in 3rd gear is 6.58 mph which is 14% faster than an M in 3rd gear 5.78 mph.
Trkr
11-30-2006 12:59:31
 Re: Farmall ring pinion info in reply to superih, 11-30-2006 05:46:10
Do you know the speeds of a super m with 14.9-38 at 1750 rpms in 2nd and 3rd gear?Thank you
superih
12-01-2006 05:24:03
 Re: Farmall ring pinion info in reply to Trkr, 11-30-2006 12:59:31
Super M with 14.9x38 tires at 1760 rpm 2nd gear=4.81mph, 3rd gear= 6.25 mph
IHFan
12-02-2006 17:14:11
 Re: Farmall ring pinion info in reply to superih, 12-01-2006 05:24:03
Got speeds for a 560 on your chart? 34 and 38 info would be great?
Trkr
12-01-2006 09:49:49
Thanks
smp
11-29-2006 19:01:06
Thats why 1st gear isn't the answer, you have got to go to a speed limit, any gear.
champspa
11-29-2006 17:01:41
going from a 15.5 to a 16.9 x 38 will give a 8% increase
