Farmall C-153 in a B
Dave Jr
12-02-2006 13:32:51
I am thinking of putting a C-153 motor in a Farmall B. What will it taketo get this done so that it looks stock?
460anger
12-02-2006 16:26:49
 Re: Farmall C-153 in a B in reply to Dave Jr, 12-02-2006 13:32:51
some of the 153 cranks are not drilled for the piliot bearing.never look stock to a IH guy has to many ovbiously things. Good luck i have done a couple.Makes a very snappy puller!!
Shaggy
12-02-2006 15:15:28
The only thing that might give you a problem is the steering shaft. There is no notch in the block but I would think you could cut it out with a little patience. I am thinking about doing the same but I am going to use a A front end. If you have a junk block you can cut a piece out of the it to put in where the starter hole is on the 153.
Shaggy
