Front Hubs
Muench
12-05-2006 16:35:05
I was wondering what kind of hub i would need to use to put a 5 hole alluminum wheel on my 39 farmall h and where i might find them
AC
12-05-2006 16:59:58
 Re: Front Hubs in reply to Muench, 12-05-2006 16:35:05
Do like I did. Re drill your front ennd to accept a C pedistal. Then put Massey 22 5 bolt hubs on it. Works well. Never seen a hub that fits an H.
ChadS
12-06-2006 10:28:54
 Re: Front Hubs in reply to AC, 12-05-2006 16:59:58
IH wagon running gears had hubs that fit onto the H/M spindles with the stock H/M bearings. Only thing I had to do was to take the outer bearing race, remove it from the bearing itself, and use it for a bushing if the wagon bearings are used.
460/560
12-06-2006 06:34:02
Is that a IH C or an AC C?
AC
12-06-2006 15:10:01
 Re: Front Hubs in reply to 460/560, 12-06-2006 06:34:02
IH "C" .... Chad, are the running gear hubs 5 or 6 bolt?
ChadS
12-07-2006 09:51:02
 Re: Front Hubs in reply to AC, 12-06-2006 15:10:01
6 bolt, Rims from a IH baler or bout any square baler, are 4X15 some are 5X15 which works great for a 400X15 tri rib tire. Some of the utility tractors, like the 350, 460, etc etc had hubs that can fit too, but you have to mismatch the bearings to make it work,,, Chad
