350 Utility Block
H Puller
12-12-2006 19:35:09
Is there any difference in a 350 Utility engine block, and a 350 row crop engine block besides the front cover???
puller1
12-15-2006 17:11:46
 Re: 350 Utility Block in reply to H Puller, 12-12-2006 19:35:09
the utility block has larger bolt holes for the front cover,you can use reduced thread inserts in the large holes down to 3/8 in. or you can use a porta band saw and cut the mounting ears off and use the utility front cover.
FarmerSid
12-13-2006 05:35:02
Not that I could tell when I put a 350 Utility block in my H other than the front cover.
jkohn
12-13-2006 05:08:01
ghfghdgvkdfg;herg;r;vfgrgfadfg;dfg;iog;dvdig;orodvjjsditifgkfjfkdfa
