Governor surging
TOH
04-21-2002 14:21:33
I have a U moline and was wondering what I could do to prevent the governors from surging when I'm pulling down the track?
ub
04-21-2002 14:30:43
 Re: governor surging in reply to TOH, 04-21-2002 14:21:33
Sounds to me like you need to lenghten out the linkage from gov to carb.
TOH
04-21-2002 19:13:55
 Re: Re: governor surging in reply to ub, 04-21-2002 14:30:43
How far do I need to go? Will this affect my tractor from idling? I'm not sure what the problem is but it goes from a high idle to wide open, there is no throttle response.
deadeye
04-22-2002 04:58:49
 Re: Re: Re: governor surging in reply to TOH, 04-21-2002 19:13:55
If you go to the manual on the "U", it tells you exactly how to adjust the linkage. Can't remember but it is 1/2 the rod diameter longer I think when it is in the wide open position. Check your manual. I'm not sure. deadeye
Tom
04-27-2002 00:18:08
 Re: Re: Re: Re: governor surging in reply to deadeye, 04-22-2002 04:58:49
I am not familiar with MM, but I had that problem with an Oliver and I ended up shimming the governor mechanism tight. The weight mechanism with getting a few thousands play and it would jerk the throttle.
Just sharing info.
