Farmall C weight
My??????
12-17-2006 13:40:41
How lite can you get a C with 11.2 or 12.4x36 tires and striping all the unnessary parts off for pullin? Can you get it down to 2500 with a 120 lb driver?
c puller
12-18-2006 15:21:51
 Re: Farmall C weight in reply to My??????, 12-17-2006 13:40:41
I pull mine at 2500lbs with 250lbs driver. yea alot of work! front-end, seat, hubs with pressed steel 13.6x38
My?????
12-18-2006 18:04:07
 Re: Farmall C weight in reply to c puller, 12-18-2006 15:21:51
Thanks! How dose it pull in 2500? I was thinking of pulling in 2500,3000,3500 like the Allis B/C, Case VAC, Oliver 60, and Farmall A/B in the classes only with larger 36 inch rubber! Do you think it will be competive in 2500?
CLIFF S
12-18-2006 18:14:56
 Re: Farmall C weight in reply to My?????, 12-18-2006 18:04:07
C puller Do you have a C-153 In it to need 13.6x38 tires on it,I pull a Super C with 14.9x36 tires but it still has all its Oem Parts other than the Hyd arms and pto that i took off and its 2950 with me on it.
Sleddog
12-17-2006 15:27:59
2650 with 60 pound driver.
My ????
12-18-2006 04:39:44
 Re: Farmall C weight in reply to Sleddog, 12-17-2006 15:27:59
How?
CLIFF S
12-18-2006 04:33:47
I seen one pull in 2750 with a 153 in it and weight on the tractor too!
MJF
12-19-2006 19:41:50
 Re: Farmall C weight in reply to CLIFF S, 12-18-2006 04:33:47
Hey Cliff that wouldn't have been the Shivley C that pulled in the 2750 with 13.6-38's at the first pull of the year would it
CLIFF S
12-20-2006 05:08:32
 Re: Farmall C weight in reply to MJF, 12-19-2006 19:41:50
Thats the tractor i was thinking of and i bet with slightly smaller tires and lighter rims it could get in 2500lbs
MJF
12-20-2006 15:00:00
 Re: Farmall C weight in reply to CLIFF S, 12-20-2006 05:08:32
that tractor should have never pulled in that class with 13.6-38's, but I guess thats how it goes. That tractor is stripped way down. I'm pretty sure the fan and water pump was off it among other things, It could prolly get to the 2500 though
CLIFF S
12-20-2006 17:20:54
 Re: Farmall C weight in reply to MJF, 12-20-2006 15:00:00
Then Agian its no worse than the So Called Case VAH that has Aluminum front Axle with a hevier combine engine with many changes that i bet will make 2500lbs! Shoot my VAC is striped down (No lights or brackets ETC)but still weights 2750 with me on it But with only 19 HP its no threat at any weight! The IH RED ones are a differnt story! They might evin get a win or two!
