4055 vs. 6030???
ALAN4020
12-20-2006 14:13:42
I have the oportunity to buy a 4055, 2wd, four post rops, 10 hours on major by a john deere dealer, new clutch, looks good, known good maintainance history, turboed 466 engine, less than 7000 hrs. Around $25,000. Will pull farm stock.
What is your input? Buy this tractor or should I wait and eventually buy/build the 6030 I"ve always thought about? We don"t have many 6030"s here in central WI. What kind of $ is a 6030 going to cost me these days, running or otherwise. Will I gain much with a 619 to justify the added trouble, cost, and fewer pulls that I will be able to pull in due to non-stock?
Just wondering
P.S. How do I justify either tractor to my significant other?? Back Blade to plow snow? Roto-tiller, finishing mower? W/O a cab it won"t even be a good dog house!
JDGnut
12-21-2006 20:43:33
 Re: 4055 vs. 6030??? in reply to ALAN4020, 12-20-2006 14:13:42
Sounds a little steep.. but it depends on what been done to the tractor inside... Also check out the pulloff.com site for tractors.. There's been a nice looking 5020 w/619 for sale here.. Found these on the pulloff.com site
Pro-Farm John Deere 4455 Admin :: Edit 4:53:41 pm 14 December 2006 466 cu. in., Fresh fuel p- pump, Simpson water injection, Rack & pinion steering, S3 charger. 24.5x32 V-cut tires, Aluminum rims, SFI cage, 3 disc 11 in. crower clutch, trans gears 7, 7 1/4, 7 1/2. Extra hood. Idea for new NTPA Pro-Farm class. 6000 lbs bare. No overseas calls. 26,500 dollars obo. serious inquiries only. 320-267-7332 Mark E-mail 320-267-7332 website
John Deere 6030 3000 RPM Hot Stock Admin :: Edit 01:25:16 am 12 December 2006 NEW 680 CID Engine, Performance Camshaft, Sleeves Fire Ringed, 3x3 Turbo, P-Pump, Dual Feed Injectors, .093 Inj. Lines, Electric Water Pump and Fan, Aluminum Radiator and Fuel Tank, Heavy 2 Disc Clutch, 20.8-38 Firestone Tires on 10 Bolt Rims-JD Hubs, 4020 Fenders, Wt. Brackets, Wheelie Bars and Hitch, Autometer Gauges, New Paint and Decals. Tractor Runs Excellent!!! Extra Parts Along With Complete 5010 Tractor If Wanted. 28000 For Everything!!! Performance Diesel & Repair E-mail 402-992-1828 website
Good Luck...
Brad4010
12-20-2006 18:52:08
First you have to ask yourself, $25,000 for a farm stock puller??? No sir. Buy a 6030 for around 8-10 grand. Needle bearing the diff, port polish the head, stroke crank, pistons, sleeves, pump, and turbo. I would say for the same money you could build yourself a real contender.
Dairy Farmer
12-20-2006 18:12:57
Well i'd have to say go with the 4055 for now, but (i can't really say much as i'm a rookie at this sport too)It would probly be cheaper to buy the 4055; but then again you could go all out and build the puller of your dreams as long as you have the money. anyway my opinion: go with the 4055 for now and if you have to...you could sell it as a farm stock or hobbie stock tractor(saying you put the work into it to make it into a puller) and be able to afford to build the 6030 with the money you get for the 4055. Just my 2cents worth DF
