Farmall 400 NEW PULLER
Steve Weathers
12-26-2006 16:37:50
I started pullen with a H Farmall enjoyed it so much I've got myself a Farmall 400.How does the 400 compare to the Super M on HP??? And with 1 set of rear wheel weights and my 14.9's full of water around what weight should I be at.
230 puller
12-29-2006 13:45:09
 Re: Farmall 400 NEW PULLER in reply to Steve Weathers, 12-26-2006 16:37:50
I have a 400 with fast hitch, a wide front end no wheel weights and the tire just have air in them it tips the scale at 6300 with me on it. As far as power goes I got beat by an Oliver and a MM this year.
ih4ever
12-27-2006 17:57:59
The 400 should be the same or possibly a stronger than the super m. Most super m's would have the 400 or 450 kit, since the block is the same for all three. It is rated at 50.8 hp roughly and should rund near 60 hp with out much modification. I would guess your tractor weighs in the neighbourhood of 7500 lbs with you on it. It is a good 6000 lb tractor. Depending on your personal use / needs, you may want to strip it for pulling.....it sure is nice to have moveable weight to put where needed.
c281
12-27-2006 15:56:15
I would say 6800-7000 w/o a FH.Mine weighs in at 6000 with me, 14.9,cast wheels no FH but with pump,resevoir and lpto.I weigh 250lbs.
MR X
12-27-2006 09:48:54
As I've pulled a 400 for the last 10 years, I had a nice, really long post all written out for you of things to try. After spending 10 minutes wrtiting it under the name "Dave in MN", I found that someone else had reserved the name. Thanks alot!!! It irritated me so much, I don't feel like spending another 10 minutes doing it over. By the way, I tried to help out some other guy with the value of a IH 350 on the IH forum. Thanks again.
JakeF
12-26-2006 20:39:10
Probably about 7200. I pull my 400 but have pulled the fasthitch, hydraulics, hyd valves, pump, steeing support and tank. It weighs 5500 with dry 16.9-38's on cast wheels. Jake
Steve Weathers
12-29-2006 18:48:52
 Re: Farmall 400 NEW PULLER in reply to JakeF, 12-26-2006 20:39:10
I put it on scales yesterday w/me and no weights 7240.Thanks.Can anyone give any tips to the 400 Pullen,in the 7200 and 8200 class
