ChadS
12-30-2006 08:51:19
Re: Blue flame - can anyone explain in reply to B-maniac, 12-29-2006 18:52:08
Overlap is when they open the intake valve while the exhaust valve is still open, yet on its way closed, letting a part of the intake charge escape with the exhaust. The flame lights up when the exhaust opens burning the gas out. Overlaped cams dont belong in low rpm engines with stock, or even slightly higher compression tractor engines. Its cyl pressure is the main reason why they do cams with overlap,,,, its so they can say they have 13 to 1 compression ratio,,, and run it on 93 pump gas. 93 pump gas is good for up to 180 psi in some engines,,,, 13 to 1 cyl pressure is way higher than 180,,,, See how that works??? Now take the stocker engine with low compression, stuff that same overlaped cam in it, and you drop HP and torque from even lower compression than what it had stock. Its a vacuum leak. Just like you said,,, might run at high rpms,,, not low though,,,, A tractor cam grind to me,, and this is my opinion,,,, so dont shoot me,,, LOL,,, A cam in these low compression engines should be made so it pumps up cyl pressure. If they want to play with some sort of overlap, take it to the point of its highest mechanical cyl pressure and stop right there. Save the fancy grinds for the big huge high compression strokers that can stand to lose some cyl pressure. Chad
