Oliver 66 pulling
drew
04-25-2002 11:40:55
i was looking to pull a oliver 66 row crop at the local antique pulls. are these competitive in the 3000 pound class? i think i read somewhere they weigh 3100 ish what about one on steel wheel and hydraulics weigh? i am trying to get the tractor to weigh 2750 pounds what would need to be done?
thanks in advance
Tim
05-01-2002 05:49:54
 Re: oliver 66 pulling in reply to drew, 04-25-2002 11:40:55
I recomend if your pull has a 3000 class just to stay at your 3000 weight. Where I'm from the 66 is the tractor to beat in the 3000 class. Your only competition will be WC Allis Chalmers that is in the older class because they weight about 3000 but in the newer class the WC has a hard time to get in because it went to a styled body, but they can take their fenders off and get under. They pull because most of the time they have a WD 45 kit in the engine.
missery
04-25-2002 17:27:36
my 66 with no weight added, is 2956 lbs. i pull it in the 3500 pound class.this is a very good tractor to pull with. i could get ,maybe 75 more pounds off it, but that is it. i pull antique farm so, i am limited to what i can alter.any more questions feel free to ask. Dave.
Lee W
04-26-2002 06:19:54
 Re: Re: oliver 66 pulling in reply to missery, 04-25-2002 17:27:36
I have two friends that pull 66's in the 2500lb class.
missery
04-26-2002 17:19:00
 Re: Re: Re: oliver 66 pulling in reply to Lee W , 04-26-2002 06:19:54
how did they get it down that low in weight? i would love to get mine that light. Dave
Lee W
04-27-2002 08:02:25
 Re: Re: Re: Re: oliver 66 pulling in reply to missery, 04-26-2002 17:19:00
They use a smaller gas tank,and make new hubs for the rear wheels, plus light rear rims. I think they are using 10x38 rear tires.
missery
04-28-2002 17:27:08
 Re: Re: Re: Re: Re: oliver 66 pulling in reply to Lee W, 04-27-2002 08:02:25
please remember that i said , that i pull antique stock.no light hubs,small tanks. i have 10 inch pressed tin wheel, on 10 inch rubber. narrow front end. thanks for the reply though. Dave
Kirk N
04-26-2002 18:54:51
just a few things to lighten up olivers--have pressed steel rims instead of cast centers, remove hydraulics or power lift- they made bare transmission covers, check your organizations rules first but the pto can be removed-only 8 bolts & it saves 100 to 150 lbs & a plate will have to be made to cover hole in diff. case. Narrow front is lighter than wide fronts & check rules again but i usually remove the fenders this saves a few pounds too.
