300 Farmall engine
Dave S.
01-09-2007 02:57:30
I have a farmall 300 engine and I am trying to identify the head & block. Part of the head # is ground off and as near as i can read it is 36?479 R1, can,t read the 3rd number at all but think the 4th # is a 4, the head casting code is 7*25*A.
The block casting # is 362743 R2, C-169, and the casting code is7*26*A, and the ser# on the side of the block is 31084.
The ser# on the tractor it came out of is 18766.
Is this head a gas or a fuel head and what can I do to improve power ouput without buying another head. I am using it around the farm and maybe take it to the local pulls once in a while. I am using 3-5/8" pistons and sleeves and haviing the cam ground to 350 specs.
Dave S.
01-10-2007 02:32:34
 Re: 300 Farmall engine in reply to Dave S., 01-09-2007 02:57:30
Thanks MJF and ChadS I appreciate the help. Dave
MJF
01-09-2007 14:39:38
300 gas head...361479R1 it's a good head I'd stick with it
ChadS
01-09-2007 08:34:47
The cam are the same in the 169's and the 175. Its a gas engine, never had the dual fuel option in that engine. Early 300 engine,,, A codes were for first year production, so a 55 or a 56 production year. Give it a rebuild, fresh surfaces on the lifters rocker arm tips, shave the head a little, do some carb, governor, ign upgrades and do what ever you need the tractor to do. Real good power upgrade for the H,,,, ChadS
