Farmall 400 Carb HELP
Steve Weathers
01-13-2007 15:02:28
Whats the very most you can do to the 1 1/4 IH updraft carb to get extra power or is they a custom bolt on replacement or maybe a upgrade kit. thanks steve
PORKY B.
01-14-2007 22:31:51
 Re: Farmall 400 Carb HELP in reply to Steve Weathers, 01-13-2007 15:02:28
Steve check out Denny"s carb shop website. There are some very interesting items on here for pulling tractors. We also pull with a 400 Farmall.
Steve Weathers
01-16-2007 14:09:04
 Re: Farmall 400 Carb HELP in reply to PORKY B., 01-14-2007 22:31:51
Do you have anything done to your carb.What weight class do you pull and do the best in??
Dave Morgan
01-15-2007 09:42:39
We had a 450 one time that we drilled the main jet and installed M&W pistons...It really pulled strong and lasted in the field...My uncle had one set up the same way, but his got the oil bath air cleaner full of bees wings when he used the 450 on our BearCat sheller-grinder-mixer and it started smoking white and combustion come out the crankcase ventilator.
in other words, a dry air cleaner would be a very positive addition and I believe it could be done all inside the original oil bath assembly.
