Farmall M weight
Hank
04-26-2002 09:46:50
Does anyone know the difference in weight of a early model M rear case compared to a late M rear case.
Tenn Transplant
04-29-2002 01:23:20
 Re: Farmall M weight in reply to Hank, 04-26-2002 09:46:50
A local salvage yard guy told me that
a 1939 M rear casing is 40 lbs lighter than the
1940-1954 due to redesign in the mold.
Jeff
04-28-2002 11:33:17
Someone told me that early farmalls (at least H's and M's) had different metals used in the wheels and gears. i think it was something with zinc in them. They changed it during the war because of shortages i would assume. i don't know if that would change the weight of the rearend but i suppose it might. my friend told me that is why he liked the older ones cause the metal they used was harder and didn't break as easy.
jeff
BUD BARENIE
05-03-2002 06:09:05
 Re: Re: Farmall M weight in reply to Jeff, 04-28-2002 11:33:17
THE 1939 M AND H WERE DEFINITELY LIGHTER THAN LATER MODELS. AFTER 1939 THEY REDESIGNED THE TRACTOR TO MAKE IT HEAVIER FOR LONGEVITY !!!!
Same
04-26-2002 10:09:21
They're the same
Hank
04-26-2002 11:58:37
 Re: Re: Farmall M weight in reply to Same, 04-26-2002 10:09:21
Many people that ive talked to have said that the early case is lighter then they started breaking them when they were on steel so IH made the later cases stronger and heavier.
Denny Frisk
04-27-2002 15:26:59
 Re: Re: Re: Farmall M weight in reply to Hank, 04-26-2002 11:58:37
Hadn't heard of that problem... Have heard quite a bit about the capscrew holding the bull gear on the axle breaking the head off & falling under the bullgear & pushing a hole in the bottom of the rear end. Back in those days FARMALL had their own foundry... and I suspect but am not positive made lots if not most of their own castings. Continual running changes & refinements were made I'm sure. LOT of surface area on the main rear tub on those tractors... 1/32" greater thickness would add a substantial amount of weight.... PLUS a lot of added strength I would imagine if the weight was in the right places.
