Advancing camshaft timing for more torque...after
MM ZAck
01-17-2007 13:53:39
We've heard for a couple of years now that advancing the camshaft one tooth on our Moline tractors will increase the low end torque output of the engine. This actually works as we have done it. My question is that if I have the camshaft reground on my ZA for a little more torque, is there still an advantage to advancing it one tooth?
Drew
01-17-2007 15:08:14
 Re: Advancing camshaft timing for more torque...af in reply to MM ZAck, 01-17-2007 13:53:39
If you get a reground cam, you need to degree it in to what your cam card tells you. I would dyno it with the cam where the card recommends to get a baseline and then start moving it foward from there.
How many degrees is a tooth?
MM ZAck
01-18-2007 08:38:22
 Re: Advancing camshaft timing for more torque...af in reply to Drew, 01-17-2007 15:08:14
It's a 60 tooth drive gear on the camshaft and therefore if you advance it one tooth it would be 6 degrees. Would that be enough to throw things off?
Mike n Mo
01-18-2007 09:30:20
 Re: Advancing camshaft timing for more torque...af in reply to MM ZAck, 01-18-2007 08:38:22
It would be 6 deg in terms of camshaft rotation, but since cam timing events are expressed it terms of crankshaft rotation, it would be 12 deg different. Make sense??? Mike
Think about this
01-18-2007 09:25:39
One cam tooth is equal to 6 cam degrees, which should be equal to 12 crank degrees since the crank turns at twice the speed of the cam. This would seem to make sense because all degreeing is done at the crank not the cam.
