Compression ratio and pump gas???
Jim in OH
01-22-2007 10:01:10
I know that the answer is more complex than just compression ratio (e.g, timing, air/fuel, etc..) but as a start, for a first time builder:
About how high can I go (compression ratio) and still expect to be able to use premium pump gas (92-93 octane)? About 10:1????? ?
Jim
dboll
01-22-2007 16:22:13
 Re: Compression ratio and pump gas??? in reply to Jim in OH, 01-22-2007 10:01:10
premium is a joke if you have much compression, buy good gas it burns cleaner and has lead in it
Jim in OH
01-22-2007 20:40:12
 Re: Compression ratio and pump gas??? in reply to dboll, 01-22-2007 16:22:13
this is to be a part time puller, and still be in the "field" sometimes... I guess I am not willing to make a trip to the airport for gas to do some brush-hogging.. :)
Thanks all for the answers... my current plans are to be at about 9:1 (just cc'd the heads, piston craters and did stroking/machining calculations)
Jim
dboll
01-23-2007 12:39:27
 Re: Compression ratio and pump gas??? in reply to Jim in OH, 01-22-2007 20:40:12
what are you going to brush hog with a bored/ stroked motor? The only thing I can imagine would be mind altering plants!!!
G/MAN
01-22-2007 13:47:48
As you already alluded to, there is no hard and fast rule for compression ratio vs. octane. Engine temp, load, camshaft specs and a ton more factors all affect that. 10:1 on 92-octane would be really pushing it in an old-fashioned tractor engine with an ineffecient chamber under high loads, in my opinion. Especially if you get into big-bore engines where the flame front has to travel very far across the cylinder.
ChadS
01-24-2007 16:58:48
 Re: Compression ratio and pump gas??? in reply to G/MAN, 01-22-2007 13:47:48
Cyl pressure is relative to fuel octane. 200 psi wont run on 93 alone. The camshaft can let you run 87 octane in it if you put a big enough overlap in the grind in most cases. Spark plug location, and single fire ignition systems hinders firing big bore cyls with high cyl pressure.
champspa
01-22-2007 12:53:36
yes
