Enlarging intake with acid
MolineU52
01-24-2007 07:54:54
I have heard of enlarging intake manifolds by filling them battery acid and capping off the ends. But what keeps the acid from eating up the flanges. Any one heard of this or could give some pointers would be greatly appreciated. Thanks
buickanddeere
01-24-2007 15:53:46
 Re: Enlarging intake with acid in reply to MolineU52, 01-24-2007 07:54:54
Extrude hone is what you want for the intake, heads and exhaust manifolds.
MolineU52
01-24-2007 17:19:58
 Re: Enlarging intake with acid in reply to buickanddeere, 01-24-2007 15:53:46
Yeah Ive heard of that, but im looking for inexpensive, and I've heard of battery acid being used but do know exactly how.
Crutch
01-24-2007 18:23:47
 Re: Enlarging intake with acid in reply to MolineU52, 01-24-2007 17:19:58
I believe its purpose is to keep inspectors from seeing grinding marks where rules say "no porting".
You could buy a cheap die grinder and an expensive cutter and do much better.
Cut the manifold if you have to and open things up if you need to. Then have it welded back together. Try to keep it going from the plenum to the runner in the head and keep it tapering down. Air wants to take the shortest route to the vacuum source so keep that in mind. The inside turns can be widened, or in other words, make it easier for the air to take the shortest route around the turns. The outside of the turns should be kept small so that the cross sectional area can remain the same. This way you help keep velocity up and avoid fuel seperation as much as possible. That is just for starters. Don't cut it so the charge speeds up and slows down anywhere if possible. It should continue to accelerate until it passes the valve head. Just my thoughts.
ChadS
01-25-2007 07:47:18
 Re: Enlarging intake with acid in reply to Crutch, 01-24-2007 18:23:47
Sandblast it before porting. blast it again when your done, harder to tell if anything has been done. Chad
