John Deere A
Phil
04-23-2001 03:51:04
I have a John Deere A I am getting ready to rebuild as a stock puller. I was wondering if anyone had any suggestions on what to do to it.
Thanks
Bryan
04-25-2001 20:00:14
 Re: John Deere A in reply to Phil, 04-23-2001 03:51:04
Boys your deer can run but they cant out pull AC in stock class. (Thats where it counts been there)
Deerepower
04-26-2001 19:53:39
 Re: Re: John Deere A in reply to Bryan, 04-25-2001 20:00:14
put your $$$ where your mouth is
Blow you away
04-27-2001 02:53:35
 Re: Re: Re: John Deere A in reply to Deerepower, 04-26-2001 19:53:39
How much you got to loose?
blow this
04-27-2001 20:26:49
 Re: Re: Re: Re: John Deere A in reply to Blow you away, 04-27-2001 02:53:35
the only thing that an AC is blowing is smoke. Have yet to be beaten my one
You're in Dreamland
04-28-2001 03:12:46
 Re: Re: Re: Re: Re: John Deere A in reply to blow this, 04-27-2001 20:26:49
You live in Dreamland or just visit for awhile
every now and then?
burns...what model
04-28-2001 08:03:44
 Re: Re: Re: Re: Re: Re: John Deere A in reply to You're in Dreamland, 04-28-2001 03:12:46
Just exactly what class, model, divison are you talking about?
G Taylor
04-26-2001 19:13:08
Stock class is all about the driver, weight balance,tires & drawbar length. A few extra HP from the "A" with a straight exhaust, a dry air filter in the oil bath housing & a dyno session setting mixture/timing.
Pull dog
04-24-2001 16:34:52
Hey man i am in the same boat. What year is yours. I would like to keep talking to you so i kinda know what to do. So far i think i am gonna get it running smoth and put a G JD carb on it because i heard that the 1 1/8 inch bolts will bolt right up there
well keep in tuch. thanks
Greg H.
04-23-2001 13:18:47
unless you have a late A with the straight 6 speed transmission, I don't think I'd build one exactly stock for pulling. However if yours is a late model than by all means find some good tires, make sure everything is reliable and running correctly, pile on some weight and have fun with your stock tractor.
burns
04-23-2001 13:07:41
Well if you are serious about the stock part of the pulling. You can't do anything other than some new rings, valves cleaned up, new wiring harness. There isn't anything wrong with a reground camshaft with a stock grind (I would recommend this highly) A final suggestion would include having the carb professionally rebuilt.
If you are thinking of "stock ++", then thats a whole other topic. (one that won't make you any friends)
T L Bair
04-23-2001 18:59:12
 Re: Re: John Deere A in reply to burns, 04-23-2001 13:07:41
Nice home page Burns, I like the pictures of the progress on the G. Keep adding them.
