310 Diesel Head
Chase
02-08-2007 03:53:09
I'v got a question for you guys. I am trying to put spark plugs in a crossflow head and am wondering how big I can drill the injector holes before I hit water. Also, what plugs are you guys using sizewise. Thanks in advance.
Goldsburg
02-08-2007 07:43:04
 Re: 310 Diesel Head in reply to Chase, 02-08-2007 03:53:09
Chase -
What people do is to machine out a decent hole in the combustion chamber and then through to the top side of the head. In this hole, they then weld a fabricated sleeve that can be tapped for whatever (preferably motorcycle) spark plugs.
If you want to get in touch with someone that can do this work, call Himes Casting Repair at 317-831-2571 and ask for Bob...
Regards,
Goldsburg
dboll
02-08-2007 06:30:10
You got me thinking, I have 2 310 heads at home! A small plug out of a sb Chev should work, I suppose one could make an insert if water was a problem. Maybe some who know for sure will respond.
Cody Adgent
02-08-2007 06:37:13
 Re: 310 Diesel Head in reply to dboll, 02-08-2007 06:30:10
Drill the injector hole out for a 10mm spark plug (weedeater). the walls aren't very thick.
Chase
02-08-2007 08:29:27
 Re: 310 Diesel Head in reply to Cody Adgent, 02-08-2007 06:37:13
Does the weedeater plug have a 5/8" hex on it. If so do you drill out to about 7/8" to get the socket down in. Thanks.
