First pull this year this area.
Super77Mi
05-01-2002 09:02:20
still got to change one tire, whats an all stock super 77 weigh? do i need some wheel weights? i have a pair of oliver wheel weights.
Rich
05-01-2002 10:08:51
 Re: First pull this year this area. in reply to Super77Mi, 05-01-2002 09:02:20
Oliver S-77, with hydraulics, PTO, cast iron centers front and rear, fenders and all the tin work, no weights, and very little water in the tires, w/o driver 4350#.
A.P.
05-01-2002 09:37:42
cast or pressed stell centers on the rear? What about the front tires and rims? rear tires loaded? Tricycle or wide front? With pressed rear and front rims, no fluid in the tires, no belt pulley,with mechanical lift and pto and two sets of wheel weights around 4300 pounds with a 250# driver. Your tractor can go up or down from there.
Take care,
A.P.
super77mi
05-01-2002 10:36:59
 Re: Re: First pull this year this area. in reply to A.P., 05-01-2002 09:37:42
should have clarified better. 57 Super77, iron hubs front and back, no loaded wheels, no belt pulley, has pto, hydraulics, drawbar only.
deadeye
05-01-2002 14:39:57
 Re: Re: Re: First pull this year this area. in reply to super77mi, 05-01-2002 10:36:59
And it depends on whos scale you are weighing on. Portable scale have a tendency to weigh different that the ones at the elevators and fertilizer plants. Just have to wait till you get to the pull unless you know where everyone will be weighing in at.----deadeye
