Tires For this pull
super77Mi
05-02-2002 09:06:00
looks like its going to be a wet track, gravel on clay. i had planned on using some fairly well worn feild and road 13.6 38, with weights, but i amnow thinking about using the high cleats with no weights any ideas?
shoe
05-03-2002 21:42:59
 Re: Tires For this pull in reply to super77Mi, 05-02-2002 09:06:00
I've watched the 77's pull before, you won't be humiliated by it's performance. If the track is
going to be wet and slick I would use a taller
lug tire and weight it up to the max. Something
about those old olivers, they are hard to beat.
A.P.
05-02-2002 15:17:47
Put on as much weight as you can for the class and try the tires you have on the tractor. How short are the lugs in the middle? How rounded off is the front edge? A lot of times the tall lug tires just piles up more dirt in front of the sled making it that much harder to pull. Are you planning on pulling at Oakley?
Take care,
A.P.
super77mi
05-02-2002 22:20:45
 Re: Re: Tires For this pull in reply to A.P., 05-02-2002 15:17:47
who knows, this old S77 is stock, runs great, had the original tires rotted of it. i have a set of tires worn nearly to death, but the leading edges are square. and this hi tread set, am looking for a more evenly worn set as well. i may just go get humiliated by a Cub, who knows. its what i can afford, those other brands cost a ton, and i got this one next to free. if it does good i will invest in it more, new rings, valve job, etc.
TG in Mich
05-03-2002 09:00:03
 Re: Re: Re: Tires For this pull in reply to super77mi, 05-02-2002 22:20:45
Where and when is the pull your talking about? I live in the Brighton area. The only one I heard of is the Hudson Mills event in June.
A.P.
05-03-2002 14:32:55
 Re: Re: Re: Re: Tires For this pull in reply to TG in Mich, 05-03-2002 09:00:03
There is a transfer sled pull tomorrow (Saturday) at Oakley (North of Owosso) at the Mid-Michigan show grounds. This is the pull that was canceled last weekend due to rain. There will be another pull in two weeks on Sunday.
I live in Howell. Hope to see you at the Hudson Mills pull. What do you pull? I pull an Oliver 88 standard at the moment.
Take care,
A.P.
TG in Mich
05-06-2002 05:54:57
 Re: Re: Re: Re: Re: Tires For this pull in reply to A.P., 05-03-2002 14:32:55
I'm working on a JD B. So far I have only been a spectator at pulls. I have a few friends that have pulled in Fowlerville and at Hudson Mills. If I get my B together in time I may try to pull at H.M.
super77mi
05-03-2002 09:54:17
small club pull in Big Rapids, 55 and older 10 am sat, weigh in at 8
