G Flat Head: F49R or F486R
JD Pullin'
02-19-2007 14:41:24
Which of these two flat heads will work on a styled G to increase the compression? Will both bolt right upto a styled G? And what kind of increase in HP can you expect with a stock crank?
Thanks for all your advice!!
JDGnut
02-19-2007 20:29:25
 Re: G Flat Head: F49R or F486R in reply to JD Pullin', 02-19-2007 14:41:24
Either head will work... use the later Gasket. The early gasket will not match up to the block.. JDGnut
JDGnut
02-19-2007 20:37:17
 Re: G Flat Head: F49R or F486R Pic in reply to JDGnut, 02-19-2007 20:29:25
third party image
Early G block, later G gasket. the early head has the same small water passage as the block, but the head will work on the later block because the extra area for the water passage is blocked off on the early head.
JD Pullin'
02-19-2007 16:36:56
Also, would you get the estimated 15 HP from both heads?
JD Pullin'
02-19-2007 16:34:19
Which head is the earlier one?
Josh Wilhelm
02-19-2007 14:46:49
Both heads will work but the early one needs a special head gasket. I would estimate that you should gain around 15 hp with the flat head.
