Carb jets
Farmall 400 pul
05-03-2002 14:02:39
I have turned my main fuel adjustment screw all the way out and it still does not richen my tractor up. with the screw all the way out it still does not blow fuel smoke out when it idels. do I need to drill my jet out or do i need to put a bigger jet in it. that might be why my tractor is bogging down. the tractor is running out of fuel when the governor is opening up. any advice will me appriciated.
farmall flogger
05-03-2002 21:17:45
 Re: carb jets in reply to Farmall 400 puller, 05-03-2002 14:02:39
Open up the jet a few thousands at a time until you can get some black smoke. Here again is where that dyno would be beneficial. Those other guys are telling you right about the dyno.
Hayne D. Matthews
05-03-2002 18:06:27
Find you a carb off a 706 gas or 503 gas burner combine.
Andy
05-03-2002 16:54:40
Have you tried cleaning the carb. check your air filter.
