Porting and polishing
Green
05-05-2002 06:57:36
Will porting and polishing help any engine???
buckmaster700
05-06-2002 20:57:03
 Re: porting and polishing in reply to Green, 05-05-2002 06:57:36
if you not blowing a wad on the motor just gasket match your manifolds to the head and any large burs you see and let it eat save the greenbacks
G Taylor
05-05-2002 07:25:54
If port velocity/ram effect isn't lost & the intake surfaces are rough enough to keep the air/fuel mixed with turbulance on the boundry layer. Extrude hone or just port match the manifold, do the three angle valve job & blend the rough edges in the valve bowl. Serious porting requires years of experience and a flow bench.
