Air pressure in tires for 3mph antique classes
KY Case Guy
03-08-2007 07:32:46
I was just wondering what kind of air pressure other people are running in the 3 mph classes in a 6 ply, 15.5/38 or a 16.9/38 firestone 151.
joecool
03-09-2007 03:47:12
 Re: Air pressure in tires for 3mph antique classes in reply to KY Case Guy, 03-08-2007 07:32:46
on my dc, which will pull 6500-8500 3 mph classes, we use 12-14 psi. dad's cc with 13.6, 4500-6500 3 mph, 12-14. we have found that too low hurts worse than to much.
buickanddeere
03-08-2007 13:58:32
Enough pressure so the tires don't squat and cause the drawbar hitch height to drop. Too loose and tire tread bars tend to fold over rather than bite in.
dboll
03-08-2007 09:53:36
around 9-11 psi on a 20 inch hitch and a sled with alot of downpull, tracks should be flat if they are higher in the middle where you spin out raise the pressure
2 Cylinder
03-08-2007 08:10:47
You"ll need to fill in which weight classes your pulling in. Each weight class usually requires a slightly different air pressure.
KY Case Guy
03-08-2007 08:28:49
 Re: Air pressure in tires for 3mph antique classes in reply to 2 Cylinder, 03-08-2007 08:10:47
5500 lbs through 7500 lbs
2 Cylinder
03-09-2007 08:22:59
 Re: Air pressure in tires for 3mph antique classes in reply to KY Case Guy, 03-08-2007 08:28:49
In 5500 I run 12-14 lbs. pressure, 6000 about 14lbs, 7000-7500 about 15-17 lbs. pressure. But like it was state above, look at your tracks at the end of the pull when you drive away from the sled. Crowning in the middle of the track means not enough air pressure, dishing in the middle means you have to much pressure. The pressures listed above are a starting point, your tracks will give you the best indicator of adjustments needed.
2 Cylinder
03-09-2007 08:26:29
 Re: Air pressure in tires for 3mph antique classes in reply to 2 Cylinder, 03-09-2007 08:22:59
Forgot to mention, these pressures are on 16.9 x 38 tires. Different tire sizes can also require different pressures also.
