2 cylinder flywheel
Big G 1
03-30-2007 17:16:54
Hi guys I heard a rumor that someone was making billet flywhels for 2 cylinders??? Does anyone know if this is true? Where do you find one? Thanks
yuk
03-30-2007 17:31:48
 Re: 2 cylinder flywheel in reply to Big G 1, 03-30-2007 17:16:54
I wouldn't want the liability.
G/MAN
03-31-2007 21:03:30
 Re: 2 cylinder flywheel in reply to yuk, 03-30-2007 17:31:48
I think I'd feel safer with a new, quality, well-made billet flywheel on one of these mega-cube two-bangers guys are building these days than I would with a 60-year-old cast-iron one.
Drew
04-01-2007 19:36:21
 Re: 2 cylinder flywheel in reply to G/MAN, 03-31-2007 21:03:30
I agree with you G/MAN; a new, well made steel billet would be better than the original iron one.
BUUUUT, I have to really agree with yuk also. I work in a machine shop making parts for pullers, but I wouldnt want anything to do with making a flywheel for one. If the flywheel or engine came apart and a piece hit someone, you have a huge target for a lawsuit pinned to you. You can make the customer sign all the waivers in the world saying you are not responsible if anything ever happened, but with the right lawyer, those waivers arent worth the paper they are written on. If someone got hurt they will sue anyone and everyone.
If there is someone out there making flywheels for Deeres, I wouldnt mind seeing one.
ChadS
04-02-2007 08:10:17
 Re: 2 cylinder flywheel in reply to Drew, 04-01-2007 19:36:21
Ive seen laminated flywheels made for the G, welded together, and uses a taper lock device built for it. I questioned the safety issue to them, and they took it apart in front of me, looked for any signs of it being loose, couldnt find anything, and we had a long look! He said its been on it for 15 years. Lots of local, personal witnesses to it, with never a trouble. Always,,, like with any motor sport, something has got to give,, ant any time, any moment is never enough time to escape a JD flywheel spinning at 1500 rpm and takes off across the ground. it hasnt happened yet, but it could happen.
