37 A
kendak
04-04-2007 07:34:32
I found a 37 unstyled A that I want to pull with ...where should I start on the motor end ?..I know that I need to go through tranny but I need advice on the motor...I have a 47,48,& 51 A's as parts tractors also have 53 model 60 with burned rod for parts ...can i use any parts off these models? ..I know about pulley & first reduction gear off the 51 what else can I use ...have about 5 grand that the wife said I could use on this project...Help please...already have pressed wheels & hubs...brother owns a machine/welding shop so that work is covered...will #2 power block fit this model?...what bore & stroke should I use?...whose crank & pistons...please Help...thanks ...Kent
super1
04-04-2007 20:24:16
 Re: 37 A in reply to kendak, 04-04-2007 07:34:32
You need a #1 powerblock, but you can take the 71 carb of an A and put it on along with a gas manifold. if you should happen to stumble on a powerblock, you have to use the styled head, or you can use the 60 head/manifold/carb on it. i would stroke it, 9" aint as easy as it sounds, but 8 is easy. get a good cam and some head work. have an A with 6.125" bore x 7.375 stroke makin 60hp. 5.625 x 9 should make somewhere from 75 to 85hp, depends on how its done.
G Fever
04-04-2007 18:09:36
Kent,
Give Keith Merfeld a call at 563-582-8710. He can tell what to run on that unstyled A. He has a machine shop and he builds stroker cranks and borex blocks etc.... He will probably tell you to bore the block 5 3/4 and use a 9" stroke!
2 Cylinder
04-04-2007 08:18:28
To my knowledge the parts tractors you have will not interchange motor wise, they are a different bolt pattern. As far as the powerblock, a 37 A will need the #1 powerblock. Probably get the biggest bang for your buck with the stroker Crank, go as big as you can, 9" or above. Then sleeve your block oversize or find a #1 powerblock, port out the head and manifold. With this engine work done you should not need to work on the transmission. Others can give you information on the best place to have a crank done. Merfield (spelling?) is one name to look into for cranks.
