AC D-14
MIKEGRAPE
05-10-2002 09:14:34
Were taking our D-14 to our local pull 2 saturdays from now, it will go into the 4000lb antique class we put a diffrent spring on the governer so it winds up to around 2300 rpm. Hitch is at 18ins.Its my first time out is there any thing else I should do? Thanks Mike.
Vic Simpson
05-11-2002 19:56:52
 Re: AC D-14 in reply to MIKEGRAPE, 05-10-2002 09:14:34
Is your drawbar as short as possible 18 to 20 inches from center of axle.(pull a string) have your front weights as far forward and as low as possible USAP rules is 11 ft. from center of rear axle.If you have fluid in your tires take it out now! It will pull harder than you think use first gear, balance is everything. tire pressure rear think low try 7 front think high 50 weigh it from side to side. I would start at 30% front 70% back when weighing it. Good luck!
