Allis pullers / front aluminum wheels.. HELP!!
AC
04-28-2007 06:28:01
I see alot of WC's, WD's etc with aluminum wheels on the front. I have a set, and a d17 front end/hubs, but I can see how you make them fit. Whats the trick? Anyone make a light trike front end? thanks..
TN PULLER
04-29-2007 16:59:32
 Re: Allis pullers / front aluminum wheels.. HELP!! in reply to AC, 04-28-2007 06:28:01
5in 5 lug chevy rims will fit the Allis hubs
AC
04-29-2007 19:13:05
 Re: Allis pullers / front aluminum wheels.. HELP!! in reply to TN PULLER, 04-29-2007 16:59:32
YEah, but it seems the center of the hub is too big...I'll actually TRY it tomorrow..thanks..
TN PULLER
04-30-2007 08:46:59
 Re: Allis pullers / front aluminum wheels.. HELP!! in reply to AC, 04-29-2007 19:13:05
Turn it down to fit the center of the wheel. Thats what I did.
JDGnut
04-29-2007 22:55:09
Turn the hubs down on a lathe... You will not be able to use the nut style caps.. Just seal the wheel center caps to the hub.. JDGnut
AC
04-30-2007 06:38:00
 Re: Allis pullers / front aluminum wheels.. HELP!! in reply to JDGnut, 04-29-2007 22:55:09
Thanks!
JDGnut
04-30-2007 09:15:25
 Re: Allis pullers / front aluminum wheels.. HELP!! in reply to AC, 04-30-2007 06:38:00
I also drill the hubs and installed studs... (Then painted it green.. haha.. )
I just silconed the center cab on the hub.. So when you pull the wheel the cab stays on the hub..
A little heavy.. but works good... JDGnut
superh
04-28-2007 15:08:36
To fix this problem, forget the allis and finish the H. haha
AC
04-28-2007 21:47:25
 Re: Allis pullers / front aluminum wheels.. HELP!! in reply to superh, 04-28-2007 15:08:36
You pulling tomorrow?
