4020 Turbo 4430 setup or MW
LStallbaumer
04-28-2007 12:17:24
Looking at putting a turbo on a 4020
I have found a MW setup with a bad Rajay turbo. Has anyone replaced the Rajay turbo with another brand without butchering the hood and if so what model of turbo did you use.
Second Have also found a 4430 turbo setup with a turbo that does not leak oil but the end play on the turbo is excessive. It probably would work for what I want it for just fine for year. I assume the way the 4430 setup is plumbed it would flow better. ___ Would a 4430 provide more boost or would if perform about the same as a MW setup?
The real dilemma is do I butcher the hood or not. Really don't want to but would like to add the turbo.
Thanks in advance
LStallbaumer
ejr-IA.
04-29-2007 19:45:30
 Re: 4020 Turbo 4430 setup or MW in reply to LStallbaumer, 04-28-2007 12:17:24
Which M&W kit do you have.They made one that went out the original hole it has the two piece exhaust manifold.You can use other brands of turbos,look for ones used on AC tractors with the center exhaust houseing,Airesearch TO4 and a 3LD Swizter.
G/MAN
04-29-2007 10:18:06
Keep in mind that the 4020 block wasn't designed for turbocharging, and doesn't have piston cooling jets and the head-gasket sealing isn't ideal for it, either. For short periods at moderate horsepower levels, it will probably hold up fine. Hard pulling for long periods of time with not-smart horsepower output, you're rolling the dice on scuffing liners and pistons or blowing the head gasket. That said, the 4430 setup is probably better, particularly if the turbo will live for a while, but I don't know for sure if it will be a bolt-on. I'm not sure that the 4020 block will have the boss cast into it and drilled/tapped hole for the drain tube and fitting from the Deere 4430 turbo.
4010 puller
04-29-2007 07:31:13
I feel that the 4430 setup is definately the way to go. It looks much better being John Deere Parts, turbo"s are cheap and easier to find than fixing the old M&W kits. Regardless of either turbo, you will have to modify the hood or fab on your exhaust elbow to get it out the factory hole on a 4020.
