Head preferance
John
05-13-2002 05:19:33
hey, do you guys on this board that run any John Deere or even if you don't, do you guys run flatheads, or the swirl head? What is your reasoning?
thanks,
John
Gman
05-13-2002 19:10:22
 Re: head preferance in reply to John, 05-13-2002 05:19:33
I like the one with the biggest valves 2 7/8ths,the flat head and the eyebrowed head is debateable. 3 in. or bigger exhaust pipe. My two cents worth Gman
burns
05-13-2002 06:58:57
John you can find folks who will argue both heads. This is what I have found with the G flat head vs G cyclone head
Flat head:
GOOD__
*Boost the compression (Rule of thumb with a G is 10-15hp. I can't verify those exact numbers)
*Allows for 360 degrees of free flowing around stock valves.
*It is my understanding that there is more volume in the valve bowl on the flat head versus the cylone.
*Intake runner is a straight shot BAD__
*On a G, the flat head can flex under high compression. Pinning should be considered for reliablility.
*Expensive. I would guess $1000 to build a factory flat head with valve work, pinning and avaliability. Good used G intake valves go for an much as $120 each.
*You if you want to use an aftermarket G gas manifold. You are limited to Jerry's because of the notch that is cast in the block/waterjacket area.
Cyclone:
GOOD__
*Avaliability is much higher and the valves are still avaliable from Deere.
*At the bottom of the intake runner, there is a Y shape in the casting to divide the air better.
*Can be milled as much as .300" to achieve the compression boost.
*Little more meat in the casting to handle the higher compression
BAD__
*The intake valve is partially shrouded by the "eyebrow". This made the tractor less thirsty for fuel but does limit the air flow. If you can find a reliable machinist/welder. You can fill in the entire valve seat area and place the intake valve up like a Heisler/flat head.
Hope this helps. What model are you considering?
John
05-13-2002 16:00:21
 Re: Re: head preferance in reply to burns, 05-13-2002 06:58:57
I was just considering in general, My dad has a G with a flat-head, and my cuz has a g w/the cyclone head. They were arguing bout it, they say the swirl part is better cause the fuel is mixed better. dad argues the compression, but, they have their g stroked too, what is the max compression too? 200psi? or around? what's your opinion? thanks,
John
ps: how much power does your G have? do you run a flathead? I seen the picture of it, and it looks nice!
burns
05-13-2002 19:57:14
 Re: Re: Re: head preferance in reply to John, 05-13-2002 16:00:21
Before my carb/intake work, my G pushes around 65hp at 540. My 10th anniversary is coming up this December and I can't think of anything better to give the little lady than a stroker crank for the G. I bet she would be just as happy as she was with the new Benelli shotgun I bought her. ROFL
For reliability, I believe Merfeld and Schooler like 8-9.5:1 Local guy pulls a G (6 3/8 x 9.5) with around 215psi. She is a good running G
john
05-14-2002 05:11:10
 Re: Re: Re: Re: head preferance in reply to burns, 05-13-2002 19:57:14
my dad's has 68-72, depends on the day, and it's not stroked. J/w, it would be nice for your lady, I'm sure she'd enjoy it!!
email me, we'll talk on there.
shepherd_home@hotmail.com
