Farmall m starter ideas
TWL
05-20-2007 19:24:52
would anyone have an idea on a good starter option?Could one be built with the farmall nose cone and match it up with something?I really appreciate any advice.Thanks
TWL
05-22-2007 09:36:33
 Re: Farmall m starter ideas in reply to TWL, 05-20-2007 19:24:52
Thank you all for your help.I do appreciate it.
Gary Baker
05-22-2007 05:35:40
The starter that Lemmons or Marlett sells is what you want. They work good for me. Need two 1000 cca batteries with #2 ought wire. Also run a heavy ground wire direct to the starter. This system starts 660 cid engines for me.
superih
05-21-2007 17:37:37
Lemmons sells high torque starters that should start anything you can build.
mshultz
05-21-2007 12:36:03
if you need more starting power you can get a 3-bolt housing and mount a 3-bolt starter from an 806D or similar. Have also seen them drilled and tapped on a 2-bolt housing, but don't look as nice.
dboll
05-21-2007 13:56:16
 Re: Farmall m starter ideas in reply to mshultz, 05-21-2007 12:36:03
on the farm we used a chain on an Oliver or case!! Sorry guys,meant in good humor, I couldn't resist!
AC
05-23-2007 08:23:22
 Re: Farmall m starter ideas in reply to dboll, 05-21-2007 13:56:16
Ohh so thats how you start you Case...Can't Afford Something Else ...lol..AC
TWL
05-21-2007 14:39:19
Taken in good humor.Shurly someone has some ideas.It has a high torque on it now but it isn't enough.I haven't tried 2 batteries yet but I am willing to try anything.It is 540ci with lp head.Will a high torque start those with over 600 cubes?Maybe the starter is going bad?
ChadS
05-21-2007 17:36:55
 Re: Farmall m starter ideas in reply to TWL, 05-21-2007 14:39:19
Big cables a must, the battery has to be as close to the starter as possible to get the most amperage thru the cables. Ive always had to put the throttle at full idle so virtually no air enters so the compression doesnt build so quick,, seems to work when I do that. Ford soliniods (spelling) help alot too, so it doesnt burn up the old push button switches. If its a older starter, check the brushes. Might be gone. maybe a gear reduction 450 starter might work too, would have to drill the third hole in the bellhousing, but might be an alternative. Hope this helps, ChadS
AW Puller
05-21-2007 17:44:06
 Re: Farmall m starter ideas in reply to ChadS, 05-21-2007 17:36:55
"full throttle" or nooooo ooooo ooo throttle to keep air out?????
ChadS
05-21-2007 19:16:47
 Re: Farmall m starter ideas in reply to AW Puller, 05-21-2007 17:44:06
NOOOOO throttle.
