Autolite plug #
alliecat
05-28-2007 20:19:28
I posted a question on another forum about what # Autolite plug I need and i got a big high tech answer about as useful as you know what on you know what kind of hog
I pull a WC alklis with a D17 combine engine I am running Champion J8C plugs
Saturday a well seasoned and successful AC puller told me I needed a longer reach plug for my engine than what I have now in order to get the spark closser to the chamber
He didn't promise massive hp gains just a little better performance
unfortunately he couldn't remember the Autolite #
I would appreciate any help from you AC guys to save a lot of trial and error finding th eright number Thanks
ALLIECAT
06-04-2007 05:25:08
 Re: Autolite plug # in reply to alliecat, 05-28-2007 20:19:28
JUST A POST NOTE: FRIDAY NIGHT 2 FULL PULLS - MADE IT TO PULL-OFFS- WON 3500 LB - WON 4000 LB WITH 291.5- FINISHED 4TH IN 4500 LB AFTER PULL-OFF THANKS FOR INFO
ALLIECAT
05-30-2007 19:45:00
THANKS FOR ALL THE INFO YOU'RE RIGHT IT TOOK THE LOCAL CARQUEST GUY LESS THAN 5 MINUTES TO COME UP WITH THE RIGHT PLUG
TRACTOR SOUNDS MUCH BETTER WE'LL KNOW MORE AFTER FRIDAY NIGHT PULL
BY THE WAY THE AC IN AC DELCO STANDS FOR ALBERT CHAMPION !!
AC
05-30-2007 12:31:40
Ok, I'm stuck here at an auto parts store (I work here unfortunately) and the 3/8" reach Autolite is a 295. The 3/4" reach is a 64. This is for a D 17 HC gas. Straight out of the Autolite book...AC
buickanddeere
05-30-2007 09:39:01
It took almost 5 minutes to find the Autolite plugs and type this. 7/16 reach; MP4316, 4316 or 437 if you are a cheapskate. .472 reach; MP4092 or MP4093. 1/2 reach; 2634 A "big tech" answer is to assist choosing the correct plug. Whacking a piston into a plug gap. Or crusting up too long threads that extend into the combustion chamber should be avoided.
NEpuller
05-29-2007 20:02:54
I would suggest Autolite 3116 - it"s hot and does the job for me on my JD A puller. If you have any trouble with fouling, use a double washer - sounds crazy but it transfers less into the block and more heat in the plug.
Jim Johnson
05-29-2007 09:46:59
Well your best bet is to go to an auto parts store and talk to a parts guy that knows something about plugs, yes there are some out there, you'll need to know how much room you have for a longer plug.
Chances are you might have to go to a 14 MM plug but you can get an insert for that. Go back a few pages and you'll see a post that has a place to get them.
I went to a Bosch plug from a Champion that was running a little rich and had to put more fuel to it because it was too lean after putting in a Bosch.
I'm not running an Allis, just telling you what happened in my situation your's may be different.
I have a chart for different plugs but your JC8's aren't on it.
Hope this helps.
Jim
ALLIECAT
05-29-2007 05:12:29
GREAT NOW WHAT NUMBER?
THANKS
Sarah from Tulsa
05-28-2007 21:04:24
Autolites suck, try some ACs (AC Delco's). It's Allis Chalmers-stand proud brother!
