Farmall Motor Setups
ICHM
06-07-2007 07:19:23
Hey guys,I want to build a M puller. I have a Farmall 450 block, and a Farmall 450 Lp Head. Whats next? Yea I know im going to spend money.
Thanks
SNAP
06-08-2007 09:17:59
 Re: Farmall Motor Setups in reply to ICHM, 06-07-2007 07:19:23
ANY OF THE THREE WOULD BE A GREAT SUGGESTION, ALL ARE VERY GOOD ENGINE BUILDERS. SOUNDS LIKE 360-430'S CUBIC INCH IS SOMEWHERE THAT YOUR LOOKING FOR. 360 WORKS GREAT FOR US TO ABOUT 6000LB RANGE IN THE 4-5MPH CLASSES ON A DESCENT TRACK. HEAVIER CLASSES A LITTLE BIT MORE CUBIC INCH WOULD BE NICER. JUST A SUGGESTION.
SNAP.
06-07-2007 09:28:10
ALSO, I FORGOT WHAT ARE YOUR INTENTIONS? 3-5mph CLASSES, OR DO YOUR WANT TO GO TO A HIGHER LEVEL.
I GUESS THAT SHOULD BE SOME OF YOUR FIRST THOUGHTS, BEFORE YOU START WITH THE CHECK BOOK.
IHCM
06-07-2007 09:49:21
 Re: Farmall Motor Setups in reply to SNAP., 06-07-2007 09:28:10
Im looking to run 4mph - 6mph classes. I would like to run around 2500rpm's.
TWL
06-07-2007 16:10:23
 Re: Farmall Motor Setups in reply to IHCM, 06-07-2007 09:49:21
I have a 540ci Marlatt engine that I would consider selling.Price one first,then send me an email.
SNAP
06-07-2007 09:24:07
DETERMINE WHAT KIND OF CUBIC INCH YOU WANT AND HOW MUCH YOU WANT TO SPEND. BASICALLY A ROTATING ASSY. CRANK, RODS, AND PISTONS. SOUND LIKE YOU"VE GOT A SOLID FOUNDATION. OPTIONS,OPTIONS!
AC
06-07-2007 09:23:39
Call Gary Baker..money well spent.
IHCM
06-07-2007 09:51:36
 Re: Farmall Motor Setups in reply to AC, 06-07-2007 09:23:39
AC, Do you have a number, address, email, or website on this guy. I would like to talk to him.
Thanks
superh
06-08-2007 12:07:49
 Re: Farmall Motor Setups in reply to IHCM, 06-07-2007 09:51:36
Gary Baker 734-678-9688
supermpuller
06-07-2007 10:24:33
Baker is good ,so is Paul Marlatt, 765-938-2227, Lemmons 765-938-1808, you can't go worng with any of them.
