TA question
Farmall 400 pul
05-16-2002 18:35:13
on my farmall 400 the tractor will slip on the low side starting out sometimes. but if it catches when you let the clutch out it will hold. I have never pulled it on the low side and i need too. If the ta catches on the low side when I start will it slip on me when i go down the track. I can put it in 5th gear on the low side and choke the tractor down with the brakes and it will hold. will the tractor hold under pulling condition in 1st on the low side. any advice would be appriciated.
