Help
Need to put my M on a diet...
Vic
05-17-2002 15:36:42
Hey guys,
I have a 49 M that I am trying to get into the 4500lb stock class. It currently weighs exactly 5000 with me on it. I'm about 185 and me losing weight is out of the question cause I like pizza too much.
Anyway, once the belt pulley is off, what else can I do to save that weight?
Is it even possible to lose 500lbs on an M and still remain stock?
Thanks in advance for the help.
Vic
Dr. Evil
05-25-2002 18:27:41
 Re: Help - Need to put my M on a diet... in reply to Vic, 05-17-2002 15:36:42
Easiest way to lose 100 pounds is to find 100 plces to Lose One pound. Remove the belt pulley, PTO, and Lift-all. Hope your running a short drawbar already. Lose the oil bath air filter...run a couple dry pleated paper filters. Do You really need a battery box? Or the generator? And You could drain a gallon of coolant I bet...And You haven't spent a penny. Run a 4-ply rear tire... steel disc wheels frt & rear...weld-up a light weight seat, cut the excess axle bar length off and I bet You weigh in close to 4000#
D dude
05-20-2002 18:45:09
You were talking about not wanting to mess the paint up. I would be really careful taking the parts off the tractor and then find some alumnium plates. Polish them out then use them to cover the holes on the tractor. Not only do they keep oil from splattering all over the tractor but they look good to. Well theres my two cents. D Dude
Rich B
05-18-2002 18:55:03
Vic If you are able,or willing to,loose the cast iron wheel centers front and rear.Also PTO may save you a little.My buddy pulls a M 4500 and up does real well in Div II type pulls.4500 is possible pretty easily, good luck. By the way nice lookin tractor!! Rich B
hpuller
05-18-2002 18:21:50
You can drain some oil out of the rearend to help cut weight. You can also run your rear tires tubeless to cut some weight.
JCM
05-18-2002 15:52:57
IF THE PICTURES ARE CORRECT START OFF BY LOSING THE BELT PULLEY AND THE LIFTALL PUMP...HATE TO SEE YOU MESS UP THE NICE PAINT...GOOD FOR MAYBE 150LBS....
randy hall
05-19-2002 10:26:14
 Re: Re: Help - Need to put my M on a diet... in reply to JCM, 05-18-2002 15:52:57
i agree with you. i'd hate to see the paint messed up, because i painted it !
Allis puller
05-17-2002 18:16:17
Putting on pressed steel rims will drop you quite a bit and most of the strict clubs allow them.
Doug in OR
05-18-2002 19:14:23
 Re: Re: Help - Need to put my M on a diet... in reply to Allis puller, 05-17-2002 18:16:17
All of the above... and take the hydraulic pump off too. Good luck - from what I've seen, you'll still be dieting for the last 100 - 200 pounds.
