300 Block
Farmall H Pulle
07-06-2007 13:27:16
I found a block and the numbers on it are 36274R2 is this a 300 Rowcrop block or not?
Thank you, Miles
puller1
07-08-2007 11:32:48
 Re: 300 Block in reply to Farmall H Puller, 07-06-2007 13:27:16
look for the casting C169= 300farmall,orC175 = 350 farmall,the only difference in rowcrop & utility is the front timing cover,if you already have an H you can use that timing cover & plate behind the cover.Everything is a direct bolt in replacement.the only thing you have to watch is the main bearings for the crankshaft you use the bearings for the crank you are using whether it is from an H ,300,or 350.The 300/350 are the same
Dave S.
07-07-2007 09:22:10
I put a 1955 300 farmall block in my H and the casting # on it is 362743 R2.
