Any Ford Pullers out there
Rob Mo.
07-20-2007 11:44:03
Hey, I pull a Ford 960 & I"m looking for you other guys that hook w/ one also. I am wanting to get some info on how to set mine for the next pull, just for some ideas. Sent me your e-mails & we"ll talk. Later
er
07-23-2007 13:13:19
 Re: Any Ford Pullers out there in reply to Rob Mo., 07-20-2007 11:44:03
I pull a 960 Ford, I use 24 of the small 30lb pie weigthts and put 4-5 40lb skidsteer-compact tractor weights on the front. I"ve got firestone 13.6X 28 usually run 8-10 lbs of air.
PatsPOS
07-20-2007 21:29:13
hi, Rob...I pull with a '63 4000 SOS...not exactly the same tractor, but kinda close. I don't think I'd be good for too many tips...I usually manage to place dead last in the 4500# class, although at the last pull I went to, I fared SLIGHTLY better...seventh out of nine!
Reckon you might say I'm still learning...only been on the hook about a dozen times.
Good luck!
Pat
Rob Mo.
07-21-2007 16:28:53
 Re: Any Ford Pullers out there in reply to PatsPOS, 07-20-2007 21:29:13
Yep, we are slightly different. I've been down the track for over 8 years now. I seem to fair out pretty good this year. I'm running w/ the "tough" tractors out there & am staying right w/ them. Missed the last hook by 5' in 2 different classes. Lot of people would be pissed, but I was happy to be right there with them. It's all about getting the tractor balanced & right tire pressure to make it hook up. Figure all that out & you are going to be right up there with the best of them.
