1370 case puller
irishredm
07-22-2007 20:01:24
how much hp is possiple with miner adjustments and any stock upgrade turbos from other tractors
R.D.F.
07-23-2007 18:54:11
 Re: 1370 case puller in reply to irishredm, 07-22-2007 20:01:24
A 1370 can easily pull with 250+ hp. Keep the trans. pressure on the high side and snug up the torque limiter disc. If your trans is now in GOOD condition don't be afraid to have a good time, the red guys will soon quit talking to you cause you should consistently get on top of them. We had a lot of fun with ours, Dale
irishredm
07-23-2007 19:24:41
 Re: 1370 case puller in reply to R.D.F., 07-23-2007 18:54:11
don't know a lot about the case brand yet but the class we will be in there are not any rules for clubs but the tractors have pressed steel rims and turned up some put turbos on 4020 and a simple d ring hitch nothing to over the top i just don't want to go out and destroy the ps on the first run thanks for all the info nick 563 379 1954
HJ
07-25-2007 10:49:36
 Re: 1370 case puller in reply to irishredm, 07-23-2007 19:24:41
We used to pull a 1370 in the local farm classes and did really well once we figured out running a little faster helped. We bought it new in 72 and farmed with it for 25 years. Only thing we did to it was turned the RPMS up and turned the fuel screw all the way, put it in 3rd 3rd and started beating the Deeres and IHs. Best tractor we ever pulled. No substitute for cubic inches!!
mEl
07-23-2007 04:32:27
I don't know specifically the answer to your question because I don't know how far you want to go but will tell you that the engine will make more power than the torque limiter will stand without modification, also since the main clutch is C2 powershift clutch slipping the clutch in the process of getting big boost pressure up will destroy the p/s clutch. If you are going to pull stock classes ok but more will be a challenge holding these parts of the power train together. One of the strongest Cases in the nation is owned by a good friend and he uses a gear drive slipper combo. Hope this helps. mEl
irishredm
07-23-2007 09:01:23
 Re: 1370 case puller in reply to mEl, 07-23-2007 04:32:27
that is the kind of info i need any way to beef up the stock clutch we would like to keep it mostly stock if we can thanks
mEl
07-23-2007 16:10:51
 Re: 1370 case puller in reply to irishredm, 07-23-2007 09:01:23
Case used one of the powershift clutches (C2) as a main clutch in all the rps34 transmissions. The clutch on the engine flywheel is only a torque limiter. This transmission is NOT suited for the highest levels of tractor pulling competetion as building boost with clutch slippage will destroy the c2 clutch by warping the plates immediately. A standard transmission with 1/2 gears in the range box differential mods and a slipper is the only way to go. Maybe if you are not after the top levels of competetion you would be alright but serious pullers will not be useing that setup. As I stated previously one of my friends is running what many consider the top diesel Case and he is running the old trans setup. If you are going to use the 1370 trans for max power application, good luck. mEl
