Steel rear wheels
Dan
05-20-2002 10:54:07
I'm new to pulling, but I need to lighten up my tractor, about the only thing left to lighten is the rear wheels on my Farmall H. I would like to replace the rear wheels (cast) with pressed steel and I have a couple of questions. How much weight will I save doing this, and what size pressed wheels will fit in a "H" rim? Then do you weld the disc to the rim or what?
Thanks
Dan
Ohio H
05-20-2002 19:20:34
 Re: Steel rear wheels in reply to Dan , 05-20-2002 10:54:07
Dan: Find a set of oliver 77 nine bolt hubs (2 1/2" axel). Have a machine shop re-key them with farmall axel keys. Buy a set of 38" nine bolt wheels. Miller tire.com has new wheels.
Andy
05-20-2002 18:14:47
You take everything off the axel, and get a hub to fit your axel size, and bolt your wheels on, and then put your tires on them, no welding, just bolts, Andy
