Drawbar set up
Jim M
05-20-2002 15:39:26
Which will give more down pressure to the rear of a tractor hooked to a sled with the same distance back from the axle. Hooking to the top of the drawbar using a pull pin and factory type clevis bolted to the top of the drawbar or using a higher drawbar with a straight clevis and the point were the sled chain hooks to the clevis is the same as the first one using the hook on top of the drawbar???
