1066 pullers
ih460puller
08-01-2007 21:51:12
Is it possible to take out the pto pump and the hyd lift pump and still get proper lubrication from just using the pump on the multi control valve for power steering, the t/a, and both the range and speed trans?
minnesota red
08-02-2007 19:34:24
 Re: 1066 pullers in reply to ih460puller, 08-01-2007 21:51:12
why would you take the pump out?
you can take the lift platform off and lose the majority of the weight with the pump still in.
at any rate,i don't believe the side pump has the capacity to run the TA.
it would do everything thing else without trouble,but the TA need alot of oil and pressure.
