1206 question
jerm
08-06-2007 14:09:52
I'm looking to build my 1206 for the 466 hot farm class what has to be done to the motor??? should I have the block harded or not really.any info would be great as I'm just starting out.jerm
jerm
08-07-2007 13:39:22
 Re: 1206 question in reply to jerm, 08-06-2007 14:09:52
what about the dt407 would that be better or not???
Tim and Sue
08-07-2007 14:26:38
 Re: 1206 question in reply to jerm, 08-07-2007 13:39:22
The dt407 will still not be enough to be competitive. What injection pump can you use in the class you want to pull in? If it's a 466 class, you should run the maximum cubic inch. Tonight I'm putting a dt414 in a 706 just to be competitive in 8500 lb class. Good luck!
Tim and Sue
08-06-2007 16:40:34
I pull a stock 1206 in 9500 and 12000 lbs classes. It"s not worth your time or money to make the motor a 466. Start out with a DT466 to be competive. There are more performance parts out on the market already for the DT466. Best of luck to you! P.S. If you want to sell your DT361 I could use a back up!
brother
08-07-2007 12:57:16
 Re: 1206 question in reply to Tim and Sue, 08-06-2007 16:40:34
I agree do NOT use that motor from your 1206 to build with. It will NEVER run as good as a dt466 block
