Degreeing a Farmall M Cam
Help!
08-22-2007 16:34:17
I got my M cam back from bullet cams and now I need to degree it. How hard is it to degree a cam. Thanks
puller1
08-24-2007 18:46:14
 Re: Degreeing a Farmall M Cam in reply to Help!, 08-22-2007 16:34:17
check the current degree of your cam with a straight key, however many degrees you are off you can have a machine shop mill you an offset key,for every degree offset .005", for example 5 degrees = .025", install new key and check degree,if it goes wrong way flip key around. Hope this helps
Buzzman72
08-22-2007 16:55:33
In their paper catalogs--remember those days?--Isky Cams and Comp Cams both had detailed instructions on how to degree a cam.
Might check out the Comp Cams website to see if that info is online. Same technique, no matter who made the engine.
Buzzman72
08-22-2007 17:14:18
 From Isky Cams Website in reply to Buzzman72, 08-22-2007 16:55:33
Here's what the Isky Cams website had to say:
Buzzman72
08-22-2007 17:03:30
 From CompCams Website in reply to Buzzman72, 08-22-2007 16:55:33
Try this link for a PDF:
