Gman, what paper air filter fits in the Gconversion?
al
05-22-2002 18:54:38
Garland,that's my question. email me if you want to.
thanks,al
Gman
05-23-2002 17:31:43
 Re: Gman, what paper air filter fits in the Gconversion? in reply to al, 05-22-2002 18:54:38
Hello Al. haven't heard from you in awhile or seen in post. Guess you been readying that "G".About that air filter I used a inner air filter from a 6600 ford don't have the #. I removed all the screen wire and inserted the filter up in the cannister,then cut a hole in the drip pan (3 in.) and installed a spring loaded door in the pan.I put apiece of buffer pad soaked with WD 40 in the bottom of drip pan,I run with the little door in drip pan open when pullin and closed just idling around.I don't think the Big inner filter will flow The "G" is the reason I put the port in the drip pan,with this set up keeps every thing neat and stock looking.I purchased a new computer outfit(lightning hit old one) if I can learn how to scan a picture I'll send it to you sometime I'm I work now. Later garland
