Good Low RPM Tachometer
39 Farmall M Pu
09-14-2007 08:24:13
Well, I have seen this discusion many and many times about good tachometers and just wanted to let all you fellow pullers know that I found a good low RPM digital tach. It is made by Glow Shift. They are out of NJ and advertise them on Ebay and their website which is www.glowshiftdirect.com . It is a very good value at $49.99 plus $5 shipping. I installed it on my 39 Farmall M in about 20 minutes and it works great. It is a digital read out and reads in incriments of 1 RPM. Most tachs I was looking at were all by 100 or 10 RPM increments. It also has a built in shift light which I adjusted to be about where my tractor hits the horn on the sled. All in all, I am VERY satisfied with my new tach. I plan on ordering more of them for my other pulling tractors. Just thought I would pass on the word. Oh yeah, sorry JD pullers but it only works on 4,6, and 8 cylinder engines.
Tony
alliecat
09-21-2007 16:35:28
 Re: Good Low RPM Tachometer in reply to 39 Farmall M Puller, 09-14-2007 08:24:13
i got mine and hooked it up but it doesn't read right
i tried setting it like the instructions said but it only reads 0 when running
i guess i'll call the tech line monday
thanks though it's a cool looking tach
alliecat
09-21-2007 20:29:31
 Re: Good Low RPM Tachometer in reply to alliecat, 09-21-2007 16:35:28
I have it wired just like you said
if I turn on the switch and press the button once it reads 2400 but when I start the tractor it reads 0 and flashs all sorts of numbers some times it wont program when the engine is running like the instructions say to
39 Farmall M Puller
09-21-2007 21:14:28
 Re: Good Low RPM Tachometer in reply to alliecat, 09-21-2007 20:29:31
Well, I am no expert on any of this, but sounds like it is not getting a good signal from the coil for some reason. Are you running a resistor with your coil? I don't know if that would make a difference of not??? Keep me posted on what you find out.
Tony
39 Farmall M Puller
09-21-2007 17:52:38
As long as you have the green wire going to your negative side of your coil (positive if you are set up on positive ground), the black wire going to a good ground, and the red wire going to a 12 volt source, it should all work. Make sure you have it set on 4,6,or 8 on the back of the tach. Hope all turns out well for you.....if not, let me know. I have already ordered more of them for my other tractors.
Tony
alliecat
09-21-2007 16:35:17
Mike n Mo
09-16-2007 06:09:52
Does it trigger off of points?
39 Farmall M puller
09-17-2007 07:07:19
 Re: Good Low RPM Tachometer in reply to Mike n Mo, 09-16-2007 06:09:52
Yes, it has three wires to hook up. One goes to a ground point, ones goes to a 12 volt switch, and the other goes to your negative side of the coil.
Tony
Mike n Mo
09-16-2007 06:09:32
alliecat
09-15-2007 17:34:49
thanks i ordered mine last night hope it's as good as it looks
it might be a good invesgtment to try and resell some at pulls and so forth
alliecat
09-15-2007 17:34:36
alliecat
09-15-2007 17:34:31
alliecat
09-14-2007 19:01:27
thanks for the tip. is the shift light a separate part like it looks?
i really like the way this unit looks.
i think i'll order mine now
39 Farmall M puller
09-15-2007 02:42:43
 Re: Good Low RPM Tachometer in reply to alliecat, 09-14-2007 19:01:27
The shift light is built in with the tachometer. The tach has its readout and then if you look you can see 6 led lights around the readout, these LED lights are the shift light. I really like the design. The shift light is easy to adjust as well! Hope this helps a little.
Tony
